PEX elbow fitting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by STEVEN INFANTE, Jan 13, 2019.
  1. STEVEN INFANTE
    STEVEN INFANTE New Member
    Jan 13, 2019
    New Windsor
    Has anyone ever encountered the following:
    3/4" PEX heating lines with stainless pinch rings was installed for over a month working correctly.
    Last night one elbow fitting end that was connected came off the fitting completely. They pinch ring was still on the PEX and properly crimped.
    I have never seen a properly connected PEX crimp fitting separate.
    Have anyone seen this?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    There are several many manufacturers of pipe and fittings, and imo, it is best to stick to all one brand. Some of the tools and clamps have go/no-go test fittings to confirm the proper adjustment of the tool.
    Was the system pressure tested before it was put into operation?
  4. STEVEN INFANTE
    Jan 13, 2019
    New Windsor
    Yes I pressure tested the system. In my years working with pex, I have seen split fittings, bad crimps, kinked pipe that breached, but never a good crimp on a fitting that popped off after the system was in use for a month.
  5. Master Plumber Mark
    Master Plumber Mark Sensitivity trainer and plumber of mens souls
    Feb 6, 2005
    Sensitivity trainer.. plumber of mens souls
    That would scare me a little bit....
    I know that those Pex crimping tools can come out of calibration and not really
    clamp down properly on the ring.... If that turns out to be the case I would be
    worried about the rest of the system---
    this is the reason I use only wirsbo aquapex...
    I dont trust any of that crap
    cacher_chick likes this.
  6. STEVEN INFANTE
    Jan 13, 2019
    New Windsor
    I used barrier pex and the pinch rings from supplyhouse. I crimped them with a ryobi battery power tool. It has a built in gap test. This was for a apartment building where I took out a 1 mil btu steam and replaced with 6 IBC modulating/condensing units. In all the years I have been doing this, I can tell you I have seen a fair share of fails, but this was a first
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    It might be good to clarify your description to make sure we understand what you mean "one elbow fitting end that was connected came off the fitting completely".
    I am reading this to to mean that the fitting pushed out of the end of a section of tubing.
  8. STEVEN INFANTE
    Jan 13, 2019
    New Windsor
    Yes that is exactly what occurred. It was connected, pressure tested and in a operation for a month.
  9. Master Plumber Mark
    Feb 6, 2005
    The work you did looks good...
    I guess those are condensing tankless systems of some kind...??
    what brand are those anyway??
    how much damage did this all cause when it blew loose??
  10. STEVEN INFANTE
    Jan 13, 2019
    New Windsor
    _
    Luckily where the fitting was there was a crawl space underneath so no real damage. Just no heat as the the LWCO tripped, of course only on one of the coldest days of the year....
    They are IBC condensing/modulating with DHW. I like them because they use a full tube manifold in the heat transfer block as opposed to plate system so less chance of calcifying blockage and they only have 73 interal parts as opposed to triangle tube, navian, etc. which have many more
Similar Threads: elbow fitting
Plumbing Forum, Professional & DIY Advice 90-Degree ABS Lo Heel Inlet Elbow Fitting question Jan 24, 2015
Plumbing Forum, Professional & DIY Advice Copper fittings: elbow AND offset? Jan 18, 2007
Plumbing Forum, Professional & DIY Advice PVC Fitting - Using Elbow w/inlet w/toilet drain Aug 17, 2005
Plumbing Forum, Professional & DIY Advice Shower arm can't reach the recessed drop ear elbow Jun 11, 2019
Plumbing Forum, Professional & DIY Advice 4" drain cracked at elbow May 8, 2019
