the.timmer
Over the weekend we installed a new bathroom to have one on the 2nd floor. Ran out of time before being able to install everything, but were able to get the tub connected to the drain and set the toilet. Left the sink drain sticking up about 6" above the subfloor for now. When it came time to test the toilet, it doesn't drain. When you flush it, the bowl fills, but nothing goes down.
I pulled the toilet, ran a line through the bowl out the bottom of the toilet, it went through - no problem. Took the toilet outside, filled the tank and flushed it - no problem. I then set the toilet again and it flushed somewhat, but was inconsistent. Ended up finding that the wax ring was no longer making a seal and air & some water was being pushed out the side/bottom of the toilet but most of it went down the drain. Went and got a new wax ring which sealed it, but also put me back at my original problem. The toilet will flush but won't drain.
I'll post a picture of it later, but the drain first connects into the rest of the drain system from the basement at a 4" pvc, goes up through the first floor to the second and then reduces to 3". It then goes to a Y connection and splits off to the toilet, and the other side goes to the sink, then to the tub.
The tub drains fine, and when pouring water from a bucket through the toilet flange, it seems to drain fine. Toilet is a Kohler Wellworth Classic, which is what we have in the first floor bathroom. We were thinking it may be a vent problem, but the sink drain that is 2' upstream from the toilet is wide open, and I've tried drilling a 1 1/2" hole in the drain, a few feet downstream from the toilet but it still has the same result.
