ChrisBeall
10" x 54" resin tank
16 lbs gravel
1.5 cu ft CR10 resin
Fleck 7000SXT valve
18" x 33" round brine tank
Incoming hardness 20 - 21 gpg. 2 adults in household. Community water supply with good pressure.
Issue: the softener seems to gradually fall behind. Today I measured hardness of 10 gpg with 100 gal capacity remaining (plus 150 gal reserve). I'm looking for the opposite, where each regeneration recovers more of the capacity than has typically been used since the last regeneration.
Current settings, most of which are as recommended by the vendor:
DF GAL
vT dF2b
CT Fd
C 30 (unit was sold as 48K capacity and that was the initial setting, but my reading here advised using only partial capacity as a tradeoff to save salt, so I've done that)
H 20
RS rc
RC 150
DD 30 (unlikely to ever be reached unless we're away for an extended time, in which case I'd probably shut everything down)
RT 2:00
B1 10 First backwash
BD 60 Brine draw (observation shows that the check valve shuts off actual draw from the brine tank after about 20 - 25 minutes)
B2 5 Second backwash [vendor had recommended 10; but I think this is the setting the valve came with; I don't recall changing it.]
RR 10 Rapid rinse
BF 12 Brine fill (which I figure equals 3 gal = 9 lbs salt = 36,000 typical grains of hardness) [vendor had recommended 10 and 'actual setting varies depending on system size'.]
FM t1.2
Everything on the softener seems to be working correctly, except the result. Does anyone see issues with these settings? If you have recommendations, I'd appreciate knowing how you derived them, as I always like to have some idea of why I'm changing something.
16 lbs gravel
Fleck 7000SXT valve
DF GAL
vT dF2b
CT Fd
H 20
RS rc
RC 150
RT 2:00
RR 10 Rapid rinse
FM t1.2
