New Rheem Tankless Issue
Discussion in 'Tankless Water Heater Forum' started by Jemmypaeg, Jan 21, 2020.
  1. Jemmypaeg
    Jemmypaeg New Member
    Jan 21, 2020
    Kelowna
    Hello, I recently had a Rheem EcoH200DVLN-2 installed by a professional plumber/gas fitter, the only portion I did myself was run the PVC for the venting and had him verify it's correct. I purchased the unit separately. After about a week it started throwing an error code 10 as soon as any tap is turned on, which is supposed to indicate an issue with venting.
    I used 2" CPVC on the exhaust and 2" PVC on the intake, both runs are within 1' of each other in length, there are 2 90s and then a straight 30' horizontal run outside the home. Dipswitches are set correctly for longer 2" runs and is good up to 45' with 5 90s. I've reset it a few times with no change.
    The unit has no issues running, and is moving a lot of air, you can feel it blowing strongly at the side of the home. I contacted Rheem and they're sending me a new blower motor, but I have my doubts if that will fix the issue as this one is running.
    Any ideas or things I can do to troubleshoot further?
    Thanks in advance.
Similar Threads: Rheem Tankless
Tankless Water Heater Forum Rheem Rtex 06 tankless electric water heater Apr 30, 2021
Tankless Water Heater Forum Rheem Tankless Troubleshooting Mar 2, 2021
Tankless Water Heater Forum Rheem Tankless Problem After Texas Freeze Feb 24, 2021
Tankless Water Heater Forum Scratching head - Rheem rtgh-95dvln tankless making 'whomp' noise on startupp Apr 6, 2020
Tankless Water Heater Forum My experience with Rheem RTGH-95XLP tankless WH Feb 23, 2020
