New pressure pump cycles when reaches top pressure
RiverbedRanch
Riverbed Ranch, UT
On my off-grid homestead, I'm using 1.5" PVC pipes to bring water into my pump house from my 2,400 gallon tanks. The pump and pressure tank are brand new. Got it all hooked up and turned it on. Pressure built up until it hit 60psi. Then the pump starts cycling on and off every second or less.
Tweaked the settings up and down trying to get it to switch off. Won't. I installed the pump at roughly the height of the top of the pressure tank (so it wouldn't short out if the underground pump house ever floods). So there's a good six feet of pipe between the pump and the pressure tank. Wondering if the pump has to be closer.... Wondering if the cycling could be due to air in the PVC pipes... at a loss.
Guidance would be appreciated!
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Sounds like you need a check valve.
WorthFlorida
Currently under Chemo Treatment.
Solutions
Orlando, Florida
Valveman is always correct.
Was the empty pressure tank pre charged at 38 PSI? If the bladder is blown, pressing the pin on the schrader valve only air should come out, not water.
RiverbedRanch
Riverbed Ranch, UT
Yes, the tank was pre-charged. Though, the instructions on the pressure pump said to reduce it to 28psi, which I did. (Don't remember now if that was before or after turning on the pump for the first time).
WorthFlorida
Solutions
Orlando, Florida
Precharge for 40/60 is 38, 30/50 is 28.
