Valveman, Reach4, I'll answer both of your comments here.
It's a Grundfos 1/2 HP 230V 3 wire pump according to the tag on the pump unit. The motor part was not labeled. I removed the pump from the motor and took it apart, washed each "cartridge" with muriatic acid and cleaned out as many of the passages as I could before blowing them out with compressed air. I then re-assembled everything and put the unit back in the well and turned it on. There was no water coming into the house and the water level had dropped about 20'. I then disconnected the hose between the pressure switch and the tank and turned the pump back on to see if I could hear anything in the now open pipe. Nothing, not a sound. I thought that maybe the pipe was blocked and that the drop in water level was just the pipe priming but when I went outside the water level had disappeared completely leaving me to believe that the pump was working and pumping the water into a leak somewhere.
I then turned off the pump, unhooked the pitless adapter and turned it back on again, I had a reasonably steady flow from the pitless adapter so my leak must be between the adapter and the house. I really don't know what to expect that flow to be like but my neighbor seemed to think it was ok.
I slept on it and this morning I decided to try to see if I could poke a wire down the pipe from inside the house to see if I could find some sort of blockage where maybe the pipe was completely severed (since I couldn't even hear gurgling from the open end of the pipe when I listened) . When I removed the hose from the section between where it came up through the slab and where it joined the pressure switch there were some signs of water seeping through the loosened clamp. So I fully disconnected it and turned the pump on (the well is now full again having not been used for two days) and after a few seconds I got some water flowing, at a much reduced rate than I observed at the pitless adapter. I also checked the well and the water level was way down again.
So, I agree with Cary, that the leak is between the pitless and the house...just not sure I want to dig a 4' hole in my yard. With that said, if I were to get some sort of camera in there at the pitless end I could snake it in the pipe to have a look around. My fear with that is that the pipe makes a 90 degree left turn quite soon after it leaves the well and the camera won't go around corners very easily, especially as I can't even reach the hole with my hand to push the camera along the pipe and force it around corners.
I drew a basic diagram of my layout.
A is the location of the tank and the electronics for the well inside the house as well as where the pipe comes up from the basement slab, B is a large tree and C is the well head. The arrow indicates the way the pitless adapter is facing and the dotted line is my "theory" on the route the underground pipe takes.....I really have no idea but that makes sense to me.
Short of using a camera or digging, do I have any other options ?
