Ace of Spades
Hi everyone, just joined because I have some (read, a lot) questions concerning irrigation systems. Back story is just moved into a new house (circa 1967) which has been modernized and it has an irrigation system that was I am guessing installed in the 80's. There was a new 1.5 hp pump motor (rated 60 gal/Min 40 psi) Flotec FP5172 but not installed, system runs off a well on the property. So far what I have done is convert the pump to 120 volts (was on 240) replaced all inline valves because the later solenoids did not fit the valves (I have 4 zones) built a new manifold because I broke the old one trying to loosen the fittings, using schedule 40 pvc. Replaced the chewed up and broken wiring from the controller to the pump and to the starter relay using under ground sprinkler wiring.
Replaced the starter relay with a Hunter PSR-53 10 hp rated one (over kill) in the process of replacing the wiring from the relay to the pump using 20 amp UV 12/3 300volt. The controller wires I used 7 wire and 4 wire for the zones and relay for 2 extra zones and easier repairs later on if needed. I replaced the old Lawn Genie mechanical ratchet type controller with a new Rain bird 6000 OUT 6 zone even tho I only have 4 zones I might add on later.
Now comes the fun part, I have only located one sprinkler head close to the pump which I dug up and replaced with a rain bird 4 inch (same as what was there) The people we brought the house from put in a egress window and removed about 4 feet of pipe and one rotary paw sprinkler head which I do not know if they capped it off or what, the piece they took out shows a tee connection and self draining valves as well adding to the problem. That is one problem and the other is figuring out where the all the heads are. There is no valve wires to trace, so it's probably a case of turning it on zone by zone and see what pops up I guess.
Does every thing I have got set up sound OK? and just turning on the system won't cause any more damage IE bursting pipes and heads etc etc? Thanks for read and will be looking forward to any replies....cheers for now.
Some pics of the set up
