New Delta Shower Valve Installation
Dougm44
California
Hey guys, got a quick question for you regarding a new delta rough-in valve I installed. When I sweat the valve in, it accidently installed it about 1/8" out of level, resulting in the shower arm portion of the run being off about 1" where it was meant to be. Would there be an issue bending the run slightly so it is in line with the middle of the valve or do I need to redo everything? If I could go back in time I would probably sweat in a copper to PEX barb and run PEX to everything but I'm not sure that's doable now that I already sweat copper into the valve body. Let me know your thoughts before my tile contractor gets here next week.
Thanks,
Doug
Dougm44
California
Pull the elbow to the desired location and anchor it there.
Thanks, HJ. That's what I figured just wasnt sure if it would put undo stress on the valve joint. Its a 30" run so 1 inch deviation over that span should be OK I figured. Water is back on and nothing is leaking so id imagine im good to go, these things just make me nervous because the wallboard will be back on soon and there isnt going to be an opportunity for future inspection.
Tuttles Revenge
If you're concerned with adding stress to the joint, add a brace somewhere in the lower 1/3 of the tube.
