Need help/advice with plumbing
DIYer2018
California
Hello all,
This is my 1st time on this forum so please bear with me about my lack of plumbing knowledge :)
I just purchased my house and ran into 3 of the following plumbing issues:
*I replaced my kitchen sink with a deeper basin sink and need help with re-doing the plumbing setup. Fortunately the garbage disposal is 1 inch higher than the drain.. phew!
*The old shower valve needs to be replaced with a new, updated one. I assume I need to (1) purchase a new threaded copper pipe, (2) insert it in the new valve, (3) cut the existing copper pipe, and then (4) solder the new copper pipe with the existing copper pipe?
*I replaced my bathroom sinks and the drains/pipes don't line up correctly.
Can someone please help me? Any help is much appreciated!
See the picture below. It shows the output of a disposal to be 1.75 inches higher than the trap arm going into the wall. For your setup, what would your corresponding dimension be?
index.php
DIYer2018
California
index.php
Thank you for Reach for your response and picture! To answer your question, I won't be able to measure it until later this evening.
for your valve, all you may have to do is replace the old insides with the new ones, depending on their ages. Otherwise, unsolder the 3 pipes from the valve, clean the ends of the three tubes and insert them into the new valve. Then solder the connections.
Regarding the lavatory drain in bathroom 1, show us a picture taken from the left where the arrow indicates. Include the area at the wall around the white, and the area where the white connects to the black.
DIYer2018
California
That looks promising. I presume the pipe through the wall is ABS with some dust or paint on it. If you have enough sticking out to let you cut off the first 22.5 fitting, and if you can clean off the pipe, you could glue on a new 22.8 22.5 fitting that you can attach a trap adapter to. Make sure you get the right slope on what you glue.
Once you have the trap adapter, you can use slip fittings. Life will be good. The slip p-trap will let you attach to the tailpiece up to about 3 inches from the line straight out of the trap adapter.
So your next action item is to confirm that is an ABS pipe through the wall, and see if it wipes/washes clean.
I am picturing these that you glue these into place:
1-1/2" Hub ABS DWV 22-1/2° Elbow
1-1/2" Spigot x Slip Joint ABS DWV Trap Adapter
Then a slip p-trap goes into the trap adapter.
DIYer2018
California
That looks promising. I presume the pipe through the wall is ABS with some dust or paint on it. If you have enough sticking out to let you cut off the first 22.5 fitting, and if you can clean off the pipe, you could glue on a new 22.8 fitting that you can attach a trap adapter to. Make sure you get the right slope on what you glue.
Thank you Reach for all your help. What exactly is a 22.8 fitting?
