Navien NPE 240A issues
Teris
CA
Hi guys. I just bought a 2-story house with a Navien NPE 240A in the basement. The water heater has a variety of issues. The kitchen sink gets great water pressure and heat. The Navien is set to 120 and the kitchen sink is probably about 120. The first floor bathroom sink gets lukewarm and stays that way. The first floor bathroom shower gets fairly hot, then tapers off to cool, then warms up again and repeats that 5 or 5 times during a shower. Both of these fixtures in the bathroom have mediocre water pressure. It's not terrible, but not great, either.
The second floor bathroom - the furthest fixture from the Navien - seems to be fairly consistently hot (maybe gets to 120) in both shower and sink faucet and it's hot very quickly, which based on my reading, may mean that the system uses the built-in recirculating pump and dedicated recirculating return line to get hot water to the furthest fixture for "instant" hot water. But the recirculating pump is set to the 6:00 position, which means that it's off, if I'm reading correctly.
Next, the bottom of the heat exchanger has some kind of oily condensation (as referenced here: https://terrylove.com/forums/index.php?threads/navien-npe-240a-ng-leaking.70239/). I assume this is a a separate issue. In that thread, someone referenced a potential venting issue as the cause, but I suspect that's not the problem. I understand that Navien will replace the exchange under warranty, but I guess I'd be out a lot of money for installation if I chose that route.
I cleaned out the air filter, the cold water intake filter and the recirculation inlet filter, all of which needed to be cleaned but were not terribly dirty. I examined the check valve, which I've read can break, but it appeared (to my untrained eyes, at least) to be fine. I thought about buying a replacement check valve anyway because it's only about $6 and it's an easy fix.
Others have complained about broken flow sensors. They are about $50 and seem fairly easy to replace. I guess i could try that if you guys think it may be the issue. Is there a way to test if the flow sensor is working?
I left the recirc pump at the 6:00 (off) position and set the dip switches to all down except for #2, which is up. [Incidentally, I may have damaged the #2 dipswitch by flipping it up with a screwdriver. I wasn't sure what to use and they are pretty delicate.] I've also tried #1 up and the rest down, but it didn't seem to make any difference (though I didn't check the second floor after I made that change).
I'd appreciate any suggestions you may have. Thank you!
Fitter30
Peace valley missouri
Replace the check. Dhw heat exchanger should be cleaned once a year with vinegar. Check utube for videos. Should also have a cleanable combustion air filter inside top of cabinet. On sink faucets check the aerators for debris.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
I echo fitter30's comments. and
6:00 is correct way for the lever valve to have external loop and dip switch 2 is correct.
Depending on age, Navien will send you a check valve. They are in continual corporate denial that the defect rate after seriously short time frames is ok. They should redesign and offer lifetime replacements.
Have extra rags on hand when you do replace the check valve.
Teris
CA
I really can't thank you guys enough -- that's super helpful! I ordered a new check valve - no point arguing with Navien over a $6 part. I just moved into the house, but I will do the vinegar clean out annually.
As far as the combustion air filter, I'm not sure what that is. I cleaned the intake air filter above the fan and under the air intake pipe in the top left corner of the water heater, but I haven't been able to locate any other air filters. Is there one I'm missing on the NPE 240A?
It sounds like I can get a new heat exchanger under warranty from Navien, but the new ones seem to have the exact same issue so maybe not worth fixing given that Navien will not cover labor (I'm sure it's not cheap). Is that something a homeowner can do himself? Thanks again fitter30 and breplum!
Fitter30
They must have moved it their updating all the time.
bingow
Active Member
New Mexico, USA
@Teris, intake air = combustion air? My NPE204A manual shows only one air filter. Other thought: if recent vinegar flush by previous owner cannot be confirmed, I'd do one soon. YouTube has good videos.
Teris
CA
@bingow , I'm pretty sure mine only has the one air filter. I am definitely doing the vinegar flush soon and annually. Just not sure what to do about the heat exchanger. I can get a new one from Navien and attempt to install it myself (Mikey Pipes has a video on YT), but it seems that the new ones all have the same issue. Maybe I'll just wipe it down and not bother.
bingow
Active Member
New Mexico, USA
OK, and good luck to you. My earlier post has a typo. It is an NPE240A, not a "204". It's only 7 months old, and under warranty, but hope I don't need to make a claim.
Can't find how to edit posts in this forum!
