Navien noise
Arco
New Jersey
I have ch210 combi when unit calls for hot water the first 10 to 15 seconds it makes a screetching sound. Any ideas?
Topaazy
UA
Hey Arco.
It's something like that:
If yes,notes me.I will find solution for you!Cheer
My website:.Bitcohen.Still in beta.
Arco
New Jersey
that is the noise, it started when the 3 way valve and the mother board were changed. Navien says its the gas pressure? What do you think
Ladiesman217
MA
I am not sure if this is of any help, but I had the same noise in my tankless heater. Different brand and vintage. I did a flush and the noise was still there. The cure was to lubricate the water valve per the maintenance instructions. That noise is called water flow noise.
https://www.bosch-climate.us/files/201109161902310.TWH-V-11_125-80_Flush_and_pack_water_valve.pdf
If your 3 way valve is water flow related, that probably is the problem. If the noise only happened after your heater repair, obviously the new part is the cause of the problem.
Kal
Plano, TX
Hey Arco.
Yep I have that exact noise. Please let me know what it is and how to resolve it.
JOE.G
NY
Hi Mine will make a similar sound but only for a few seconds every once in a while, What and how should I try to lube it?
