LarryLeveen
A small coaxially vented propane heater has power, will "click on" when the control knob is turned to "Run." The burner is working properly (gas is turned on and a full flame seen through the viewing window), but the fan never turns on. I _think_ I even hear a faint click after a minute or so -- perhaps the unit trying to energize the fan motor. But the fan never runs. Instead, after a few minutes of the burner running, the unit shuts down, which I figure is the overheat protection sensor doing its job. The unit definitely gets very hot, that's for sure.
So, it seems like maybe there is a bad blower relay or some other fan controller device, or the fan itself is dead. Can anyone suggest HOW I would go about diagnosing what is wrong. The articles online that I see aren't very helpful when they say "check the relay or voltage from the board. If no voltage is recorded, you will have to replace the board or the relay." I don't really know HOW to check the voltage (or continuity). I do have a (fairly crappy) multimeter, so some assistance in troubleshooting would be appreciated.
I haven't opened the unit yet. Thanks in advance.
