Modifying PEX plumbing
Rsmith99
Oklahoma
The bottom ball valve needs to be replaced. It appears it has already been replaced before, due to the splice.
I only have about 2” between the crimp rings. I don’t know how far the fitting extends past the crimp ring.
How would you splice in a new valve? Can the crimp ring be cut, and the fitting reused?
re useable yes ! dont get even the tinyiest nick in it. other wise even the slightest barely noticeable scratch throw away , buy new .
Is there room on that bottom horizontal pipe to install a new fitting?
I dont know I cant make heads or tails out of this you said something about a valve on the bottom I see 2 valves the same height? You asked can fittings be reused . YES Last question I cant tell what your asking It looks complete no idea what this last problem is ?
Rsmith99
Oklahoma
The photos are sideways.
Rsmith99
Oklahoma
View attachment 65730 That ring marked Wrong looks to be too far to the left, don't you think? Don't save that.
Check crimps with a go-nogo gauge.
https://www.pexuniverse.com/1-2-pex-brass-ball-valve-drop-ear-lead-free
Sharkbite makes some ball valves with mounting tabs (drop ear).
https://www.sharkbite.com/products/ball-valve-drain-vent-and-mounting-tab
Thanks! I had to have the plumber redo several connections that were poorly done. I guess I missed that one.
Rsmith99
Oklahoma
I got everything back together today. So far, no leaks!
Thanks for everyone’s help!
