Alex138
Hi,
I had a 36,000 btu outdoor unit, branch box, and 4 indoor units installed. The house is a 1200 sq/ft rowhouse. The linsets are the insulated with the heavy duty white insulation, and ran through an old A/C duct and through a soffit. The upstairs linsets collect water on the outside of the insulation, and cannot be enclosed in drywall in fear of creating a mold situation. The only humidity in the house is the humidity introduced by the system. Humidity with system on is consistently 60-70%.
The indoor units are:
6k
6k
12k
9k
Total of 120 feet of lines. 11 lbs of refrigerant was added to the 36000 btu H2i outdoor unit.
Could the refrigerant be low, causing exessive moisture?
What is the proper way to evacuate/charge a multi unit system with a branch box?
Could there be an issue with vertical rise when using a branch box? (There is 18 ft of vertical rise to the top floor)
What would you do?
6k
6k
12k
9k
What would you do?
