Missouri Code drain run on the outside of drywall?
Jjayg7
Missouri
Hi! Remodeling the kitchen and moving the sink from an interior wall next to the stack, to an exterior wall about 6 feet from the stack. Can I run the drain behind the cabinets along the wall and connect to the current stack connection so as not to drill through the studs on the load bearing wall?
only certain walls have fire rating issues where penetrating the rated wall . other wise a pipe isnt required to be in a wall . Ive done it many times
