Plumber69
But the manifold is feed by half inch PEX.
Looks like 3/4" between the pump & manifold to me:But the manifold is feed by half inch pex
Yes, 3 circuits. The furnace sits about 30 feet from the manifold/floor heat piping. That is 1.5" copper. Then it converts to 3/4 pex. Then from the manifold is 1/2 for the 3 circuits. As you see in the pic.
Dana - Sorry, that 170/145 is the temps just at the floor heat. So 145 is immediately upon returning from the floor circuit. I don't know what the water temp is by the time it gets back to the Munchkin. But something less than 145. I understood that the floor input/output differential should be about 20 degreese, so seems like we are right on.
Our Munchkin is heating the rest of the house radiators and I believe it's set to 180 fixed temp. I don't think we have an 'outdoor reset'. My thought for setting this floor heat system up, was that since we have this boiler heating up all this water, why not use it for the floor heat. And since the floors only require 125 (supposedly), then the floors shouldn't make the furnace burn much more than it already is. But, whenever the floor circulator runs, the furnace fires. I'm not sure if that's b/c the floor is taking all the hot water so it validly needs to heat up? Or b/c it's wired to burn when the circulator calls it. But since the floors circulate all the time, the furnace runs all the time.
As far as heat load. The exterior walls are made of 3 courses of brick. About 660 square feet of exterior walls. (60 linear feet x 11 foot ceilings). And 5 big windows for a total 75 square feet. Right now the windows are plane old single pane glass. We'll eventually be getting good storms, but for now they are 1910 wood sash, single pane. And i'm sure they leak alot of air.
BUT, all that being said .... shouldn't the floors still feel warm??
If I was sure the issue was the 6" gap b/w the insulation and the metal shields then yes, we could blow cellulose in. But that would be a heck of a lot of holes. I'm guessing 15 joists pockets, but there's a bunch of recessed lights and I think we'd have to blow in between each one of them.
One additional option is to add back a radiator. We very specifically did not want to do this, but we left the pipes in the basement just in case we needed to.
Well, funny you should mention it, but we did put in a Trane mini split pancake unit for this same area of the house. It hangs in the linen closet with 3 attic ducts, one to each room. I’d have to look up the model # and BTU, but we mainly put it in for AC in the summer.
We do have a wall thermostat (wanted wifi, but apparently Trane doesn’t make one for this unit yet, they say next year). We haven’t quite figured out when/why this thing runs. Sometimes the air seems to be blowing all the time, and then it’ll go hours without coming on. We’ve never had a mini split before, so it’s new to us.
We also don’t know how we’d run both at once. If the Trane controlled the room temp, would we set the floor heat higher? But then it would come on all the time too. Right now the stats are right next to each other, so seems they’d be constantly battling it out.
I had one more question, sort of hypothetical, but not really. So, considering all other things equal with your heat load calculations. Would it change substanctially if we had laid the pet pipes on TOP of the subfloors? Directly under tile? I ask b/c downstairs in the kitchen, it’s the same layout, same windows and everything. We are now wondering if we can lay the pex on top and if that would change the performance substantially.
