Currently in the planning phase for a main floor (only 1 level) master bath that will also contain a washer. I did a cut and paste in paint of another persons plan that fits my layout. The attached sketch uses a wet vent setup which I've not done before. I think the washer will cause me not to use this wet vent plan. Also placement of the wet vent may need to be at the end most connection. Its a 9' by 12' room over a 4' crawl space. I've typically vented each component tied to a common vent in the attic. But if this can work then great. Thanks for pointers. Also is there any plumbing design software out there just to sketch up a plan?
