Map Pro for 1 1/4" copper pipe
Chicago
Hi Guys, need to solder some 1 1/4" copper. Can get MAPP gas anymore, will MAP Pro work? Thanks again for your advice.
Chicago
Thanks hj, I was concerned that the Map pro wouldn't heat up enough, and then I wouldn't be able to reconnect my pipes.
FullySprinklered
Georgia
Been using Mapp gas for a while. Had to get a new torch recently and bought a can of Mapp Pro with it. This s*** gets so hot so quick it's unreal.
Unless you had a reserve of MAPP gas, you have NOT been using it, because it has not been available since the factory burned down several years ago.
