I am experiencing low water pressure from time to time. The ware pressure drops but recovers after few minutes (usually within 15mins) . I have noticed it on all faucets both hot and cold side(even the water from the fridge dispenser). I started noticing this about a month ago but I suspect the water pressure in the house in general is slightly down from 2 years ago when I moved in but since change is minimal I have not really noticed it until now.
This is a large house with 4 bathrooms. I have Fleck 5600xt, 64000 water softener installed a few months after moving into the house(new construction). It has been 2 years now without any water pressure issue until last month.
When I do have low pressure (where water pressure is lower than 50% of normal pressure) I checked outside in the garden but pressure was good city pressure most likely not the issue.
Water softener is working fine for last 2 years, day overide set to 15 days and it typically regens every 13-15 days (our consumption is about 800 gal/wk). Even though I have 64000 capacity it is set to 40000 for max salt efficiency. Only thing I have done other than filling it up with salt regularly is to use ResCare RK41N (All-Purpose Water Softener Cleaner, Maintain Your Water Filtration System) a few times in the last 1 year. Not sure if it may have done any damage or block anything but I want to mention just in case. Water hardness from the city is between 19-22 and I have it set Fleck to 23.
I am looking for suggestions where I can troubleshoot this issue. Thank you.
