Jesse Salvatore
building a new (large) home. City water tap was already on lot. 3/4” poly pipe to meter only yields 6 gpm but 80 psi. Would cost thousands to bore and retap to larger line/meter and city pretty much tells me that no one else ever complained. What is the simplest way to buffer (store) water and pressurize it so we can create sufficient flow/volume to multiple fixtures at the same time. There are hundreds of threads and suggestions for boosting pressure, but far fewer well written pieces on boosting flow. One poorly drafted piece (not on this board) mentioned using (un-wired) water heaters as storage tanks as they already have pressure relief valves. Just looking for the most reliable and straightforward option (preferably without float switches if possible).
