Hello- any help with this problem would be greatly appreciated. I'll give some details first:
I have a 2 handle bathtub faucet with American Standard 1520 stems with bib seats, stem and seat pictured here:
I installed a new stem and that did not fix the leak, so I removed the seat and installed a new seat. Still did not fix the leak, so I removed the stem and replaced the screwed on washer in case the old seat had messed it up. Still did not fix the leak.
So now I am thinking about buying another new stem to try, just in case this one is somehow faulty.
I will need a 2nd stem anyway for the hot side, I am only working on the cold side right now because there is a visible leak at the cold stem/handle. I am under the assumption that a bad stem/seat at the hot side would not cause any leaks on the cold stem, right?
Any other advice or things I should try? Perhaps remove the new seat and try to clean out any buildup there?
Not sure what the next step would be after replacing the stem and seat.
Also, I didn't use any pipe compound or tape on the seat - only used plumbers grease on the seat and stem.
Thanks
Thanks
