Leach field leak?
Mike1983
Central va
Hi all,
Hoping for some advice that might save us some unnecessary repairs and money!
We are new to septic as of 2 years ago. The system is roughly 10 years old. We noticed water coming out of one of the 4 leach lines about a month ago, so we had our 1000 gallon take pumped. shortly after maybe a week water was still coming up from the same spot.
It is either the 2nd or 3rd leach line.
The company that pumped it out came back located the distribution box (charged me $250) and said they recommended water jetting it for $1250. The alternative and what they recommend if the water jetting doesn’t work was to put some sort of serious bacteria treatment ($6500)in to possibly re open the maybe clogged leach line.
I kind of expected an expert to look at the clues and maybe have a better guess as the the cause then they did. The prices also seemed quite high, but I don’t have much to go off of.
I thought about pouring some water into the DB to see if all lines were taking water or if some were blocked?
I attached a couple photos hopefully they show up and help.
Any advice would be greatly appreciated!
Fitter30
Peace valley missouri
Have you been getting alot of rain because the tanks lid should be water tight and with all the debris on the edge could rain water get in? You need septic professional not a company that guesses.
Taylorjm
Active Member
Saginaw, Michigan
Oh wow, I never knew there was a distribution box like that. I've heard of tile jetting and wondered how they get to the lines. Now I wonder if I have one. Mine was built in 1995, I don't know if they are standard construction. I'll have to do some research!
