Kitchen Faucet Located Close to Wall/Backsplash
moeronn
California
I wasn't sure if this should go here or in the remodel forum, but since it is an existing condition I'll start here.
I'm looking at a house where the kitchen faucet is installed very close to the backsplash/wall. It is so close that the handles and the base are nearly flush against the wall.
The faucet is similar in style to this one.
canvas.tif
Are there any potential issues with this other than it might be difficult to replace (or turn on and off. ;) )?
faucet
As long as it has lever handles, AND is a ceramic seat faucet with 1/4 turn operation, there should be no problems. IF it is not ceramic, but uses rubber washers, you WILL have a problem when they start to wear and the handles start shutting off closer and closer to the backsplash.
moeronn
California
Thanks for the reply. The faucet does have quarter turn handles, but I'm not sure if the washers are ceramic or rubber and probably wouldn't find out until something starts leaking. The main downside is that options for replacement will be fairly limited because of the tight fit.
