Is this an old style bathtub drain?
Jose22
New mexico
Hello
My bathtub drain seems a little different than others
i doesn't have spokes or crossbar it has 2 nipples (pictures provided)
I want to replace the shoe gasket due to a leak but i wasn't expected this kind of drain
Are you guys familiar with this style?
Also it looks like its a 2 piece drain kind of strange but then again im not a plumber so i dont know if its an old style
Thank you
Jose22
New mexico
Thank you for your answer
The picture you provided looks similar to mine yes
but if you look closely at my pictures it looks like the top part (flange) is a separate piece from the thing that threads into the pipe shoe
My shoe piece is some kind of metal like brass or cast iron something like that its not pvc pipe
So like i said before probably an old style drain
And thats why i was wondering if anybody familiar with that type of drain
Marlinman
Jacksonville Florida
Your drain flange is one piece brass. It originally had a pop-up stopper on a rocker arm. These are quite common. The photo I used is from a American Standard drain from the 50s-60s. Most plumbers in my area use a "Smart Dumbell" for removal. The cut-outs on the side will lock onto the nipples protruding from your flange.
Sylvan
Still learning
New York
I made a removal tool out of 11/4" pipe cut two notches in it to remove these types of fittings
Some of my employees used channel lock handles and a screwdriver
No need to buy a special tool
