Is there a fitting to extend hydronic radiator piping?
4lane
CT
Hi!
I have cast iron radiators fed by (I believe) 3/4" copper piping. Piping was put in before the floor tile was completed. After I completed the tile, the piping is now short about 1" or less. What kind of fitting would be best to close up this spacing? I'm thinking some male/female adapter that I can put between the water inlet and shut off valve but couldn't find anything that size...
Thank you!
Tuttles Revenge
That would be a nipple extender, which is a male by female threaded fitting. They come in a variety of lengths.. So get a few different sizes. Black iron or brass would work in a closed loop hydronic system.
4lane
CT
Yes, this is just what I was looking for, but I haven't found anything for 3/4", let alone different sizes. Do you have a specific source online for something like this?
Tuttles Revenge
Looks like it may be referred to as a fitting extension.
Another way to fix it may be to cut the copper tube and extend the male adapter. If I were to try this method I would buy a spigot male adapter that solders into a fitting. So I only had to solder the 2 sides of the coupling.
John Gayewski
Iowa
Menards (not sure about some other stores) carries a coupling that is about 3 inches long and is meant to cut to whatever size you need. I've never tried one yet, but I've thought about it, lol.
4lane
CT
I did find some general brass 3/4" NPT female 3/4" NPT male adapters but they only have a working pressure of 150 psi. Will that work?
Tuttles Revenge
We used the long couplings on a project that had dozens of freeze leaks. I think the couplings we bought were 12" long.
Tuttles Revenge
Contact a place like Supplyhouse dot com or Ferguson dot com and just ask them if they stock varying lengths. We buy them from their fire sprinkler division of ferguson.
