Irrigation Controller- Rain Detector?
Discussion in 'Irrigation / Sprinkler Forum' started by CCinPA, Jun 1, 2021.
  1. CCinPA
    CCinPA New Member
    Sep 11, 2017
    Central PA
    I need a controller where different zones be controlled by the Rain-detector. Here's my situation... I want the lawn to be controlled by the rain-sensor. But, I have flower-boxes that do not get rain, and I still want these to activate not dependent on the rain-sensor. Help?
  2. WorthFlorida
    WorthFlorida The wife is still training me.
    Oct 28, 2009
    Retired
    Orlando, Florida
    All controllers that I know of only use one rain sensor for the entire system. What you'll need to do is use a second controller without a rain sensor active. Depending on your water source, either one of these would work. If you're tied to an a irrigation pump the garden hose controller will not work, however with a garden hose it would work great for drip irrigation at the flower boxes.
    https://www.rainbird.com/products/esp-9v-battery-operated-controller
    https://www.rainbird.com/products/electronic-garden-hose-watering-timer
  4. CCinPA
    CCinPA New Member
    Sep 11, 2017
    Central PA
    I believe I found one that will work for me: Rachio 3 Smart Sprinkler Controller | Rachio
  5. WorthFlorida
    Oct 28, 2009
    Retired
    Orlando, Florida
    Find the manual and be sure it uses a moisture sensor for each zone. Since it is not mentioned it most likely does not. Rain bird has moisture sensor for some controllers but not per zone.
    I might be old fashioned but without a screen to look at and can only used a smart phone for programming and trouble shooting, I shy away from it. No other sprinkler tech, if ever needed, can work on it and you'll always need a WiFi connection. When I first started reading its marketing description, it reads like the NEST guys wrote it. All flash, we'll solve your problems, the learning part is so so, just like thermostats.
Similar Threads: Irrigation Controller-
Irrigation / Sprinkler Forum Irrigation well pump somethings doesn't pump water when cut in pressure low. Jul 19, 2021
Irrigation / Sprinkler Forum Limited flow on First zone of Irrigation system Jul 1, 2021
Irrigation / Sprinkler Forum Irrigation valve box keeps flooding May 31, 2021
Irrigation / Sprinkler Forum Bringing an irrigation system back to life May 25, 2021
Irrigation / Sprinkler Forum Irrigation, Probably a crazy idea but...... May 3, 2021
