Scooterbugg
We have been reading a lot on here about equipment selection and still have many unanswered questions. We have been looking at Fleck and Kinetico equipment but are open to all, we're just trying to educate ourselves. We have a private well, drilled in 1986 for farm use but the house wasn't built until 2005. The water test from Kinetico in 2005 showed 28 grains hardness, 2 parts iron, ph was 7. Now 11 years later it tested 47 grains of hardness with 3.5 parts iron. After running through the Kinetico 4060s softener w/ a number 4 disk it is down to 18 hardness and 1.5 iron. I have been using iron out to get it to that point, I'm pretty sure the bed is pretty fouled. We just bought the house and the only real changes we know of is that the well pump was replaced and was set 29 feet deeper in the well than the pump was at the original test (71 feet vs 100 feet in 215 foot well). We have a 3 bath house with 2 adults and 1 teenager.
Kinetico recommends their AIO iron filter 10" by 54" with Macrolite and birm w/ Fleck 2510 SXT head and a 935 or S250 softener. Our existing 4060S OD might be able to do most of the work if we install an iron filter then change our disk to a number 8 but they say it would be just out of range to get hardness down to zero. I was even considering rebedding the tanks to get back to optimum efficiency.
My primary concern at this point is why did the water quality change so drastically?...and I want new equipment to be able to handle increased capacity if water deteriorates further.
Questions: 1). I'm reading birm is outdated, I don't know what Macrolite is, and katalox lite is a much better media, so I'm thinking about buying a 10"x 54" iron filter with the same Fleck head online and installing myself ? Or an even bigger filter with the same media/head? Installing myself is not an issue, I have extensive DIY experience and a neighbor who is a retired pipe fitter.
2). I have read upflow softeners are much more efficient in water usage and salt consumption. But if I've learned anything here is that there are no absolutes. I would like to stick to a twin tank setup if possible; my work hours vary a lot and I want full time soft water. I do not mind spending the money up front if it will pay for itself over time in reduced salt usage. So is Kinetico the only option to get upflow and twin tanks? I've had decent luck w/ them in previous houses but all equipment was existing when I purchased the homes. I despise how they lock down most of their information and parts however. I will give them my money if I have to but only if their equipment is the best option in the long run. The number one determining factor for me if they have similar reliability and effectiveness is cost over time....if it uses more salt but takes 15 years to get to the cost of the more efficient unit then the payout is too far ahead.
3). I should probably get my water lab tested before any purchase? I don't want to do this more than once.
4). Why did the water quality change so drastically in 11 years, and is it. Going to keep changing? If so do I need to upsize all equipment for possible future issues?
Thanks in advance for all the expert knowledge on here. My research has already brought to light many issues I had not even considered.
