Sans1964
I have a 380 foot deep well a brand new gould 1 hp 3 wire pump. New pressure switch 40/60. Pump is hanging at around 340. Water appears to be 150 feet from the well top. Ill be fine for days and then bam no watet! The system holds pressure . I measure around 7 amps at running. I can through the switch off go back late r and turn it on and get water pressure back. Im at my wits end here. I believe the pump is going into overload but cannot figure out why. Also water in the pipes is clean and it can happen even after over 24 hours of no water usage at all
