Interesting observation regarding pH
diggity
Central MA
Well, I thought it was interesting anyway... This may come as no surprise to you folks with lots of experience, but I figured I'd post it anyway as a breadcrumb trail for any other DIY'ers like myself:
So after 12 years of living with lousy water, we finally decided to shell out some money and fix it. I decided to DIY it, not so much because I'm cheap (although I really am), but moreover because we did talk to a few local guys and none of them were really even interested in talking seriously about a real solution, probably because our water is so bad. They mostly just shook their heads and walked away, so to speak. We thought about drilling a new well, but of course there's no guarantee that the new well would be any better. So I decided to DIY it. Our water is very acidic (ph 5.25) and very high in iron (15-20 ppm), hardness (50 grains) and TDS (nearly 1500 ppm). Fortunately, it's totally fine as far as serious health risk contaminants go (arsenic, coliform, etc). It's all just nuisance components. We have a big softener, which removes most of the iron and hardness, but "most" isn't good enough when it comes to iron, and we still get staining pretty much constantly. The water tastes horrible, so we have an RO unit on the kitchen sink.
Anyway, I wanted to take the project in stages:
1) Correct the pH
2) Install new Katalox Light iron filter
3) Re-bed our existing Kinetico sediment filter
4) Re-bed our existing Kinetico softener
Pausing for a few days between stages, to observe how each change affects the water.
So I recently completed step 1, which was to raise the pH. At first, I thought it would simply be a matter of putting more calcite in our existing calcite upflow filter. But that did nothing. Really, nothing. A $50 bag of calcite was a total waste of money, as the pH barely budged. I knew I could switch to a calcite/corosex blend, but that would raise the hardness even further, so instead I bought a soda ash injection system. Since the old calcite filter wasn't up to the task, I decided to use it as a contact tank, so I emptied all the calcite and sand out of it. This was not easy because it was extremely heavy, but I managed to get it outside, where I could hose it out inside. Then I plumbed the injector in before the tank. So the water comes in from the well and the first thing it hits is the soda ash injector, then the contact tank, then on to the rest of the system. It was easy to plumb the injector in using a Sharkbite t-fitting and adapter. Wiring it to the pressure tank switch was a little trickier, but I figured it out. Really though, it's probably best to hire an electrician if you have any question at all about how to wire the Stenner pump into your pressure switch.
Anyway, here is my surprise: Injecting soda ash to raise the pH has improved overall water quality much more than I expected! The system has been running for a couple of weeks now and our water has never been this good. Our pH is right around 7 now. Taste has improved dramatically (although we still only drink from the RO), and my wife has gone for 2 weeks without having to clean the rust off the tubs and toilets! What's most surprising is that the TDS has gone down too... from almost 1500 ppm to around 1250 ppm. Somehow, adding more "stuff" to the water (in the form of soda ash) has actually DECREASED the concentration of "stuff" in the water. I have to assume that some of the TDS minerals/salts were kept in solution ONLY because the pH was so low. And that raising the pH has caused some of that junk to precipitate out. Our old sediment filter must be removing the precipitated TDS junk.
So this is my big thumbs-up for soda ash injection. So far so good! Now on to step 2 - installing the new KL filter. Our water is so bad that I was wondering if a single KL tank would be enough to oxidize all that iron by itself. But considering how much our water quality has improved already with the soda ash, I have renewed hope that we will some day have decent water!
diggity
Central MA
Good going.
What is that -- a sand filter?
Ha, I was hoping nobody would ask! Truth is, I'm not 100% sure. You'd think I'd know what's in my own basement, right? Well, after 12 years, I'd be lying if I said I was positive what it is. It's either a sediment filter or an AC filter. Filters, actually, plural - it's a dual unit. I figure even if it is an AC unit, the AC was probably fully loaded years ago, so it is in fact nothing more than a rudimentary sediment filter now. So I'm calling it a sediment filter at the moment. If I open it up and find AC, then I'll rebed it with more AC. If it's sand, then I'll rebed with clean sand or Filter Ag.
ditttohead
Water systems designer, R&D
Ontario California
Don't forget, when you raise the pH of the water, you are likely to start fouling the resin with iron. When the pH is lower, the resing tends to handle the iron and clean itself fairly well. Regardless, the compensated hardness calculations are not good for your application, you should add an iron reduction system so as to take the load off the softener. I would recommend simply replacing the kinetico sediment filter with a single tank Katalox light system. If you are using your softener for iron reduction... as you are now, especially at a higher pH, regular cleaning of the resin will be needed.
diggity
Central MA
Yup, gotcha. That's why rebedding the existing softener will be the final step in the plan. I figure the media, being a dozen years old, is probably pretty much kaput, and almost certainly needs to be replaced. But I want to install the Katalox Light system first. That's my job for this weekend. After the KL system is installed, I'm going to observe it for another week or two, then rebed the sediment filter, then observe for a couple more weeks, then finally rebed the Kinetico softener.
Speaking of the Kinetico softener, if anybody has any tips on how to get the head off, I'm all ears. It has a yoke, which I have never dealt with before. It looks like there is a pin which holds the yoke in place? If I knock that pin out, does the whole yoke just pop off? Or is it more complicated than that?
Bannerman
Ontario, Canada
Katalox Light is highly effective as a sediment filter. As Dittohead recommended, you could eliminate the existing sediment filter when you install the KL filter. If you don't discard the old sediment filter, you could opt to re-bed and plumb it in later if you find it necessary.
With regard to the softener resin, since your pH had been so low, your water acted much like Iron-Out or similar resin cleaning products which are typically an acid to assist the brine to remove iron deposits. Since it was 'cleaned' so often, the resin may not need to be replaced at this point. As your pH has now been raised substantially, the softener's current iron exposure is probably more detrimental than all the years when the pH was lower.
Recommend to fast track the KL filter install and clean the softener resin with a resin cleaner.
diggity
Central MA
OK, sounds like good advice about fast-tracking the KL. It's on the docket for this weekend.
I'm glad you mentioned about KL being a highly effective sediment filter. I had read that it was good at this, but I didn't realize it was that good. Eliminating the old sediment filter would sure simplify things, and allow me to reclaim some real estate in the basement. I guess like you said, I can keep it around and add it back in later if need be. I can probably add a spigot between the KL and the softener so that I can monitor the situation and make sure the water going into the softener isn't chunky.
