Installing Toilet in woodshop 75 feet from house with no slope.
Tim MacIntosh
British Columbia
Two pumps seems unnecessary.
It looks like you have three foundation walls you are going through. Is that what those are?
Why insulated heated box? Is it impractical to get the outside run below the frost line?
Sorry about the diagram. Left wall there is the shop, then space between buildings (19') then basement of main house, (dirt floor, two walls)
I can't get below the frost line because the main house foundation itself isn't below the frost line and I can't undermine it.
The two pumps plan is because some have suggested that pumps don't like the long gentle up situation and are designed to go straight up with gravity down from there. I really don't like having two pumps though. Would you think I could do it with the one pump plan?
Thanks
Tim MacIntosh
British Columbia
Tom, What about gravuty drain from workshop to the basement of house and then pump up to the elevation where sewer exits house?
BTW Tim might want to look at his drawing I dont think you can gravity drain w/c on a 2 inch line
Right. The barrel is in the shop and receives sewage on a 3" line. Pump output (pressurized) is on a 2". I would do the plan you suggested, gravity to main house, but I would have to undermine the footing of the main house, with a deep and big trench. Not a good idea here.
In Plan B, I thought I could maybe use a cheater vent at the top of the loop: when pump is on, vent is closed and sewage goes the right way; when pump is off, vent opens and encourages sewage to drain out of weather exposed line....
These are weird ideas maybe?
Thanks
I am not a pro. I have never heard about that concern about going up gently. I guess the concern would be that that would fill up with a solids over a long distance.
I don't know all the do and don't of pumping but I've got a company that I go through all the questions with how many fixtures length of run the head etc. then they recommend the proper pump, basin,, etc..
