jimithing78
I recently removed a 30 year old toilet and with it came the flange that was supposed to be bolted to the ground. I guess it rusted to the point of not being physically held down by anything. So that left me with this hole in the ground:
It's a 4 in pipe installed in a slab foundation. I'm redoing this floor at the same time with porcelain tile. I think I've read that the tile goes down first and then I install the flange. Is that right?
So how do I install a flange? The local Home Depot carries plastic and cast iron. Are those the only two options? The guy at Home Depot showed me one that had some sort of tapered flange that you put into the drain and rotate until a gasket forms a good seal with the pipe. I couldn't find a picture of it on the HD website, but hopefully that makes sense. Is this the best way? As you can see from the pictures, the concrete around the pipe is broken up a little bit. Thanks in advance for the help.
