I'm looking for a GE 5kcp39fg p537as 1/3 hp with brackets could be used.
Videorov
Florida
Could be used is ok too. Just need something to use for a bit before replacing the whole unit.
Thanks for the replies, I found one.
Fitter30
Peace valley missouri
That motor is used by multiple manufacturers. They make aftermarket bracket that has the ears to use a standard smooth replacement motor. Manufacturers play with hp going with a aftermarket motor go by amp draw on label. If replacement is even .1 amp less pick a motor of a higher hp. Motor shop should have what u need.
