Bannerman
Dittohead was referring to to using cartridge filters for whole house chlorine reduction. He mentioned a back-washing carbon filter being the proper method when removing chlorine at point of entry. Gary mentioned cartridge filters only as a point of use method.Dittohead says above that the carbon filter is inefficient and costly, is chlorine reduction common?
Chlorine can dramatically shorten the life of resin and valve seals and other soft components, depending on the exposure level. Most standard resin is 8% (or less) cross-link whereas 10% cross-link will better tolerate chlorine exposure. While chlorine has its uses in oxidizing contaminates and for killing bacteria, its presence can have negative effects for some particularly those with asthma and other breathing issues. As 10% c-l resin is more expensive, if you're considering a back-washing carbon filter, then buy standard resin.
Fine mesh resin can be more efficient when using a softener to reduce/remove small amounts of iron. That said, fine mesh is not often recommended even when iron is present as the finer resin packs too tightly and can restrict water flow through the softener.
A 10" X 54" tank is commonly used for a 1.5 cuft system while 12" X 52" is usually used for a 2 cuft system. While 1.5 cuft has a total rated softening capacity of 48,000 grains when the resin is first new and unused, programming is typically based on 45K grains (30K per cu/ft). To restore all 45K grains would require 22.5 lbs of salt (15 lbs/cuft) each regen cycle (=2,000 grains/lb).
Salt efficiency can be drastically improved by programming regeneration to occur when a lessor amount of capacity has been utilized. For example, only 9 lbs of salt (6 lbs/cuft) will restore 30K of capacity in a 1.5 cuft softener (=3,333 grains/lb) while 12 lbs (8 lbs/cuft) will restore 36K grains (=3,000 grains/lb).
With regards to your septic field, there should not be any issues particularly if the system is maintained and is programmed to use an efficient amount of salt each regeneration.
As you don't have any iron to speak of, a larger 2 cu/ft softener could also be utilized for your growing family. 12 lbs of salt (6 lbs/cuft) will regenerate 40K of capacity. With a metered softener, regeneration will normally occur only once the programmed amount of capacity has been utilized.
Edited to add: I just re-read your earlier post. Chlorine was not indicated in your test results and the presence of E-Coli and a small amount of iron, confirms that chlorine or at least an effective amount, is not present.
