I need help with my Jetpump well
Lurch27
Delmarva, Maryland
Someone please show me the light. I have a jetpump well depth is about 25 feet. We were getting some sand and losing pressure. So we replaced the check valve. Our well is 2inch pvc pipe. Fast forward all leak/airchecks completed at the well tie in and we still can't make 50psi regularly and have air coming in the lines still. But sand issue was resolved. We did have a leak on the house side of the check valve. What am i missing.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
A single pipe jet pump can only lift from about 24'. Sucking air sounds like you are using more water than the well can produce. Your 2" well screen maybe clogged.
Pumping sand will also wear the pump down so it cannot build enough pressure. But getting air makes me think it is a well problem not the pump.
How was the sand issue resolved? By raising the intake, or cleaning the well?
