I am having a terrible time with my wells. I dont have good pressure in my house
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by George Winn, Jul 7, 2018.
  1. George Winn
    George Winn New Member
    Jul 7, 2018
    Jensen Beach Florida
    I have a 3 inch well with a 1 hp submersible with a 120 gallon pressure tank. The tank and softener is 80 feet from my house. The supply line is 1 1/4 inch PVC. All of the water lines are fed by 3/4 CPVC which runs 60 feet horizontally along the rear of my 2 story. then the lines feeding the house are 1/2 inch. 2 bathrooms upstairs have very weak pressure. The 1/2 bath and kitchen sink down stairs have very little pressure too. I want to fix this thing right. I am tired of the whole situation and the advice I am getting. The storage tank with booster pump interests me.I also have a 2 inch line I put in from pump house to main house just in case, it is not being used currently. I have another well same size that does my landscape irrigation. I have 5 acres, 4 of which have st augustine grass which has to be watered daily as well as about 100 bamboo plants along boundaries which require a lot of water. This well barely keeps up and really needs more pressure. I have irrigation zones limited to 10 GPM but still have low pressure . I am ready to just redo the whole system well and all if I can get some design help. I hate to ramble so I will stop. I will be grateful for any advice you can give.
    George
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If you want more water and pressure than you have, we will need to know what size pump you have now and how deep the well is?
  4. George Winn
    Jul 7, 2018
    The well is 110 ft. The pump is a 1 hp Grundfos submersible. The top of water table is 27 ft
  5. George Winn
    Jul 7, 2018
    Both wells are the same
  6. valveman
    Mar 15, 2006
    Lubbock, Texas
    Probably just need to turn up the pressure switch. What pressures does it come on and off now?
  7. George Winn
    Jul 7, 2018
    Wll is 110 ft watr table 27 ft. 1 hp grundfos submesible
  8. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Is that the Grundfos 30SQ10-130?
    Post a picture of your pressure switch.
  9. State of Jefferson
    State of Jefferson New Member
    Jul 7, 2018
    Nor Cal
    I would check recovery on the well to see if you have an issue there. In demanding so much from the well I would maybe suggest a storage tank. I pump out of a very weak and shallow well on 1 acre. I pump into a bladder tank 1st, then that bleeds off slowly into the storage giving the well recovery time. Then i use a booster pump sucking out of the 2600gal storage into a second bladder take with the limit switch turned up. Water pressure and volume is great anytime i want it but the well doesnt feel the demand.
  10. valveman
    Mar 15, 2006
    Lubbock, Texas
Similar Threads: having terrible
Pumps and Tanks Well Forum & Blog. Water is life. Having to hammer pitless adapter.... Oct 10, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Having some issues May 31, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Help! I'm having well issues and I don't know what to try next. Nov 5, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Help! Keep having to reset pressure switch! Sep 24, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Booster pump having trouble boosting sometimes Oct 13, 2015
