Hot Showers - Getting the temperature just right, Top Five Tips from the pros
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
I think we have come a long way in plumbing fixture design so that we can no longer get scalded when someone flushes the toilet. Brothers can no longer tease their sisters and play these funny practical jokes. The picture above is a fun one I found on a blog spot post by Leo Matsuda. Made me think what is too hot. How to check. What to check for and what can go wrong.
I while back we did a job that suffered from cross over in the water lines. With new fixtures in place the water temperature was crazy hot. I made a mental note to warn people when we take out old fixtures. What other pointers are good ones?
What are the best tips for getting your hot water just right?
DEEP THOUGHTS on Hot Showers....
quote; What are the best tips for getting your hot water just right?
Set the water heater thermostat properly and adjust the valves handles to the temperature you want. with a thermostatic valve you can dial the temperature, with a "two handle" like the Delta 1700 series you can set the temperature and then turn the water on and off independently.
JohnfrWhipple
North Vancouver, BC
Using a Thermometer to measure water temperature
HJ. On three occasions I have seen plumbers running the water and using a hand held thermometer. In the stream while adjusting the little dabs on the rough in bits. Do you have one of these? Is any brand better than others for this task?
My guy had something like this Fishing Thermometer... I hope Jim does not read this because clearly the Thermometer is meant for fishing and checking the temperature of fish or fish water or lake water.
JohnfrWhipple
North Vancouver, BC
Setting the Temperature Digitally
I wonder if these new digital high end fixtures actually read the water temperature and self adjust?
MikeQ
Washington
This is the best thermometer I've ever had.
http://www.kingarthurflour.com/shop...+Thermometer&gclid=COys-pSWnb4CFQmDfgodtk0ACg
It will go from 60F to 120F in about 3 seconds and is very accurate and durable. Pricey but worth it. I've two of them (before they cost so much) and they are still going strong. I use them all the time.
JohnfrWhipple
North Vancouver, BC
Red Shower Lighting - Making Hot Showers - H O T T E R !!!!
This is my most repined photo.... What an amazing photo....
Think Steam.
Think Relaxing.
Think about spending time there with your partner ! Hell Ya.
Gary Swart
Yakima, WA
It seems to me that if you are a pro and installing these valves frequently, it would pay to have one of the high tech thermometers. But for a DIY doing one or two at the most, it would be an unnecessary expense. When I set the temperature on my Delta 1700, I used a large measuring cup and a meat thermometer. Yeah, it was trial and error, probably took 10 or 15 minutes. Once set however, it has never needed to be adjusted. One could probably just use sense of feel without a thermometer and do just fine.
Vegas_sparky
Digital Billy
LV,NV/ Nowhere,UT
My new shower valve was "calibrated" at the factory for 100° F, in the center position, with typical hot/cold supplies at x/y. My cold supply temp can vary pretty drastically from winter to summer, so what would be the point?
Dhagin
builder:anti-builder
Oahu
HJ nailed it in post 2. And i'll repeat for the folks at home. ;)
Set the water heater properly. It don't need to be 200F! Then set the valve upper limit stops or temp valve, using whatever combination of thermometer and container you have. No need for anything fancy, just set it up so no one can be scalded.
Of course, us pro's have all kinds of fancy schmancy tools. We like the infrared thermometer 'guns' for instant feedback, but have used any old thermometer in a pinch. Have fun & stay safe kids! :)
MikeQ
Washington
I wouldn't buy an expensive thermometer just for one install but that misses the point.
An instant read thermometer is more versatile and useful than expected. I use mine to get chickens, turkeys and prime rib cooked to perfection. Because they read so fast you can poke it around a little and find the coldest spot in seconds. Far better than a typical meat thermometer.
They are quite pointed on the end but work great for taking oral body temps quickly. The SS probe is easy to sterilize before using in the kitchen.
Also very good for gardeners to measure spring soil temperatures which will let you know the perfect time to plant. You could use a slower thermometer but it would take a long time with the multiple measurements required for good results.
I also have a non-contact IR thermometer but use it for different things. I don't find it very accurate for measuring a running water stream. Too much variability depending upon distance/aim. This is where an instant read contact thermometer shines.
