anthonydad
- Messages
- 4
- Reaction score
- 0
- Points
- 0
I am involved with a golf course clubhouse project where the owner wants the hot & cold water piping installed under the slab. The building is located in the Northeast and is a single story, wood frame commercial occupancy with unheated attic & drywall screwed to the roof trusses.
Since the pipes would freeze in the attic, my recommendation is to install the piping in soffits below the ceiling. I am concerned about leaks under the slab & overall cost of running homeruns to each fixtures from a manifold. I won't install large branch & tee mains under the slab - too much liability. There are large shower & toilet rooms with flush valve fixtures, so the homeruns will be 1" in some instances.
Also, don't hot water lines need insulation under slabs? Seems like quite a heat loss travelling from the water heater to the fixtures in the cold earth.
The owner must be from California because we typically avoid running domestic water piping under slabs - we're used to basements or dropped ceilings.
Any comments/recommendations?
