Clog
What is the purpose of this 3 pin wire harness connector on the front face of the Honeywell WV4262B1114
hot water heater gas control valve?
My hot water heater functions fine, I'm just curious what this unused port is for. For example, is it an input port for external smart home systems to control power to the gas valve, shutting it on or off remotely?
The interface looks like a 3 pin computer fan connector one might find on a motherboard.
The pins are male on the gas control valve.
The technical service representative at AO Smith was not able to answer the question, because the port is not utilized in the serial number of the hot water heater I had to submit in order to ask any question at all.
I recognize this Honeywell valve as a unit that has been installed in many different brands of hot water heaters, including brands that are not affiliated with AO Smith.
Do you knw what this port is for?
