Chris Jones
Hello,
I am having a new sump pump installed with interior weepers.
The water table is currently sitting around 8" below slab, or directly at the bottom of the footing.
Weepers are to be installed along side the footing with the bottom of weepers sitting at bottom of footing, or again, directly on top of water. So any time it rains and the level rises it automatically flows to the pit.
The installer drilled holes in the basins pre molded inlets. The bottom of these sits at 12" below slab. He says there is no problem with that. The inlets will be full at all times, but because the rest of the weepers sits higher it is fine.
Is this accurate? Should I leave as is? Or should I have him cover the holes some how and drill new ones above the water table line? Or start over with a new basin?
He says the slope into basin will help empty the weepers around the footing, and that the idea a basin should not always be that full of water does not apply to high water table.
What is everyone's thoughts? Thanks in advance
