Tspunk
Hello,
I've had so much trouble these past 2 months trying to figure out what to do about my water softener.
I've had hard water since I moved in and finally decided to buy a Whirlpool WHESFC water softener a couple months ago. I thought it would be quite simple for a plumber to install it not knowing about the fact that it needs a floor drain or some drain nearby.
In my basementn, I have a well pump that goes to a whole house filter and my plan was to have a plumber install the water softener right after that.
The CSI whole house filter drains up tot he ceiling, across the ceiling (PEX) to the other corner of my basement into what I think is called a standing pipe. Total run is about 47 feet.
I thought after reading the directions that the water softener could do the same thing, but after contacting Whirlpool, they specifically told me that 30 feet is the max run horizontally.
On another plumbing forum, someone said that it is fine to go the 47 feet. Just use a larger diameter PEX (I think he said .75") and the water pressure of the house will be able to carry it that distance.
However, after contacting Whirlpool, they said:
"The 30 foot horizontal restriction is in place because the water flowing through any longer of a drain tubing will cause enough friction/restriction to cut off the suction being created by the venturi assembly. Using a larger diameter tubing wouldn’t necessarily resolve this problem. Some of the water coming out of the machine during the recharge is running at a pace of up to 2 gallons per minute."
So, now I don't really know what to do. The only plumber that was even willing to come take a look said that he wasn't sure either. He has never dealt with water softeners and the only water softener plumbers are the ones that work for water softener/filtration companies nearby, which will NOT work on my system unless I buy the softener from them.
Therefore, I am now doing my own research online.
So, after looking at my system, I do see that I can cut the horizontal distance if I can somehow extend where the drain is.
I can cut it to about 30 feet if I don't have to go all the way to the standing pipe where everything else is being drained. I was wondering if you guys could look at my photos and see if a plumber could just add a PVC pipe that goes diagonal (see my drawing, blue pen) right to the standing pipe?
Here are the pics. If you see the red line that comes up from my water filter, it goes up and across, does a 90 degree to the right, and then down more, and then a 90 degree left, and then to the standing pipe:
https://imgur.com/a/iDpChjV
Let me know if you guys need better photos or a videos to help me figure out a solution. Thanks so much if anyone can help me!
