Help! Debris in Plumbing...what to do?!?
MikeGA
North Jersey
I purchased a property a year ago and it has been abandoned for 12 years. I installed brand new PEX throughout the whole house connecting straight from the main water. However, there is one portion that was not accessible because it sits next to the garage but there's no basement access so there was old copper water lines. I tapped into the water lines and now I have that bathroom working. However my issue has been every single shower head and faucet has been clogging up and I have been flushing the system but it continues to be a problem. I've probably replaced the shower head and the faucet three times already, I can't keep doing this Here's a picture of the latest debris, they look like tiny crushed gravel. any thoughts on what to do????
Well or city water? I would consider a whole-house filter.
I would flush the WH. Flushing is an easy DIY thing. See https://terrylove.com/forums/index....o-flush-a-hot-water-heater.79444/#post-576623 post #7. Catch solids coming out to inspect those.
What does your clogging material do when you hit it with a torch outdoors? If it is plastic, it will burn or melt.
If it stays solid, I would soak it in acid. Muriatic if you have it. Otherwise, vinegar for a long time. If it is hardness deposits, the acid will dissolve it.
MikeGA
North Jersey
it's City water and I have two other bathrooms and I don't have any other problems in the other bathrooms. In terms of the water heater it's a tankless water heater, brand new as well.
I am clueless.
I would still put some debris on a rock/brick outside. Heat until read hot. Does it melt, burn, or just glow and stay solid?
James Henry
Billings, Montana.
remove all the aerator screens on the fixtures for a week then put them back and see if the pipes are clear. you might have stirred up some debris in the main line while doing your repipe.
MikeGA
North Jersey
Why is it
Why is it only in that bathroom though...that's what baffles me. Other 2 bathrooms, laundry, and kitchen zero problems.
James Henry
Billings, Montana.
sometimes when a building is being plumbed, some dirt will get into the pipes from being stored on the ground prior to installation, that's why you always remove the fixture aerator before turning the water on for the first time. just remove the aerators for a few days and see if it clears up.
I've had sand clog a sink supply stop years after it was installed.
