PanamaJack
New to the forum and I have read several posts that address similar questions, but I dont't see anything that is exactly the same as my situation, so I appreciate the help anyone can provide.
I'm trying to plan a pump system that can push/pull water up an approximate 600 foot 1/2" pvc line to refill a 5,000 liter tank that will be used to provide gravity fed filtered municipal water to two small houses.
Vertically the distance between the source at the road and the tank at the top of the farm is about 90 feet, so I'm running up a pretty steep incline.
My original plan was to sink a small tank in the ground a few feet from the source at the bottom of the hill, then use a 3HP submersible pump to pump that water through a three stage 20" filtration system up into the tank. That was before I found out the municipal supply had enough pressure to reach the tank (although it is very iffy and drops to zero during peak hours of use).
So, once I found out I had some (albeit inconsistent) flow to the tank, I figured I didn't need to store water at the source, which was a relief, because I didn't want to have to build a compound at the bottom of the hill to house the tank, pump and filters for security reasons.
The new plan is to use a 1/2 HP inline above ground pump from the source, through a single check valve (located at the half-way point), through the filters and into the tank. My thinking is with some municipal pressure from the source, the pump wouldn't have to work too hard to go the distance.
I'm not quite sure where to locate the pump and filtration system along the line. Do I locate it just above the check valve at the halfway point, or would it be better to locate it just before it enters the tank and pull the water up the line as opposed to pushing it, which would be the case if I located it further down the line? And, does the pump need to have pressure and volume at all times in order to do what I need the it to do?
Incidentally, since I have a pretty sizeable tank storing water up top, maybe I can set the pump to only run when the float gives the pump the signal to run, AND during off hours when there is likely to be more substantial pressure and volume availability. I don't anticipate using so much water as to need to refill that often, maybe once a week...
And...what am I missing/failing to consider?
I appreciate the help!
