Have you ever seen roots like this under a toilet?
Pman6
Los Angeles
I can't tell where these are coming from. The drain is clear and there are no roots coming through the inside of the drain. There are no bushes outside. The neighbor's bushes are higher in elevation behind a concrete wall, and 15ft away.
How do i kill it to prevent it from growing back?
These are just scattered under the toilet, sipping the toilet water from the failed wax ring.
I was kind of shocked at first because I thought I had a root clog.
But the clog was actually caused by flushed baby asswipes. Bullet dodged.
FullySprinklered
Georgia
Years ago, I had one where the wax ring had been replaced by fine roots. I was called in because the toilet bowl wouldn't keep water. As it turned out, the rooter people had popped a hole just out of sight in the lower curve of the trap and the water just took a short cut and ran out the hole.
FullySprinklered
Georgia
The roots enter a break in the pipe and grow in both directions in a nicely watered and fertilized environment.
Pman6
Los Angeles
yeah, this is a concrete slab.
these roots went far to find water. hot damn.
It appears that roots are not deterred by wax, and will drill right through them. Maybe that's why my wax ring was destroyed.
Anyway, I got some copper sulfate and table salt, and poured a bunch around the edge of the flange.
hopefully this will keep them away.
someone should invent a wax ring with root killer built into it.
