I have new 3/4 tubing suspended under a raised floor using metal plumbers tape. There is plenty of room to work under the floor. In some areas I can anchor the tubing directly against the bottom of the floor joist. Other tubing needs to have a gap between the floor joists.
What are the requirements for anchoring the tubing? Is the metal strap ok? If so I can cut spacer blocks to fit between the tubing and the floor joist then tighten up the strap.
Is there off the shelf brackets for anchoring the tubing? What about noise cancellation?
