I ran this 1/2" gas line about 8 years ago to accomodate a gas grill. I now need to run a line to a gas range. At the far right in the photo you can see a coat hanger wire protruding through the plywood - this is directly below where the range will sit in the kitchen above. My question is, is it acceptable to add a 3/4" x 3/4" x 1/2" reducing tee and run both the range and grill from this valve? Otherwise, I will have to go 14 feet downstream to the next capped-off valve.
Which is preferrable, the shorter distance with less tees, or totally dedicated runs with more elbows, joints, and length?
Any input is greatly appreciated.
