DanMich177
- Messages
- 1
- Reaction score
- 0
- Points
- 0
I am installing a irrigation system and am wondering if I can use funny pipe connections on 3/4" rotor heads or should I be using a larger diameter riser such as a swing joint or straight cut off riser? Will the riser diameter significantly affect the pressure/flow to the rotor?
Some sites/threads I have read recommended only using funny pipe on 1/2" rotors or sprays.
Also should you mix and match different types of risers in a single zone or would it be better to stick with the same diameter risers on all the heads?
