Recently I've had problems where the top basket is getting clogged, reducing the backwash flowrate. This could be observed by the sound and the pressure not dropping as low during backwash. I attribute the wife's heavy water use for irrigation during a recent drought to too much iron buildup between backwashing leading to failure to properly backwash. By manually alternating between backwash and fast rinse, introducing air during the fast rinse, I managed to restore the flow and filter bed to normal without having to physically remove the head to clean the top basket. It is still a stop-gap measure as I will need to eventually remove the head for a proper cleaning. I also need to measure the freeboard to see how much media I may have lost to drain.
I asked my water guy about installing the hold-down but he thinks it will just make it harder to remove the bottom basket for cleaning. Not sure how often the bottom basket needs to be cleaned. I was hoping not to have to do more than just pull off the head and only clean the top basket.
If I dump out all the media to clean the bottom basket, will the gravel sink back down to the bottom on the next backwash when I put the mixed media back? I assume I should manually top it up it with water before putting the head back on and then do a normal backwash to re-stratify the media and gravel.
With the Clack valve what is the best way to remove all the water from the tank prior to removing the head? I thought of making an adapter to connect an air line to the inlet...
Not sure why I was over-complicating this. Added an airline fitting just before the bypass valve so I can turn off the valve on the HP tank outlet and introduce air into the line while in fast rinse sending the water to the drain. I would close the outlet bypass valve to keep the air from moving forward into the softener.
I could do the same to remove water from the softener (bypassing the iron filter first) should I need to disassemble and clean it. Meanwhile, I have a camera recording the pressure during pump cycles to monitor (and deduce flow) during backwash. Last backwash, the pressure dropped to 14 PSI.
