For Pex crimp or Flair it
mdzialo
I want to install a downstairs shower using pex. I noticed that there are two kinds of fittings for pex - crimp and plastic flair-it fittings. The flair-it fitting look simpler. Are they simpler and as good?
Thanks for the assist.
OldHouse
Pennsylvania
If the 'flair -it' is anything like the plastic PEX compression fittings that Lowes sells I don't think they are intedned for 'behind the wall' plumbing applications.
At least the ones at Lowes say it on the package- though it tiny print.
I'm just a DIY though- the Pro's will have the really final answer on this.
There are compression fittings for pex, but if you have much to do, their cost gets prohibitive vs the crimp type. From what I've seen (and by no means am I an expert), if you aren't using a compression fitting, you need an expander tool. Wirsbo then uses a ring of the same material around the tubing after it is inserted into the fitting for additional strength. The others use a metal crimp ring to hold the tubing over the fitting. So, with Wirsbo, you only need the expander tool and the fittings. The others, you need the expander tool, the fittings, and the crimp tool.
