FOAMY123
Hello,
I've attached a photo to help the description.
I have an EcoMinder II softener which was in place when I moved in several months ago. It's producing soft water, there is salt in the brine tank, etc.
Toward the end of the brine draw, really during tank fill and fast final rinse - the drain starts to get filled with foamy water. The water coming out of the discharge looks normal, but as it splashes into the drain - it starts to get foamy... almost as if someone put soap into the drain. This doesn't happen on the backwash stage - so I've ruled out something else (like soap) in the drain.
I've tried plugging the air gap to rule out a venturi-effect of bubbles from the discharge pipes....
Sometimes its bad - meaning it overflows the floor drain (a lot); and sometimes I just see it peek out of the drain like the head on a good pour of beer.
I use pelleted salt, not solar salt.
Nothing else I can think of to share....
Any ideas are appreciated - hoping someone knows the cause and can help - as when it overflows the floor drain it can be a real mess.
THANK YOU!
THANK YOU!
