Floor support for 600 gallon water tank
Cahoffa
Yukon, Canada
So, maybe I'm misinterpreting the pictures, but I took the blocks stacked between the wood beams and the earth to be stone (often with a layer of wood shims directly under the beams). If you have wood cribbing directly on the earth, that's not good.
Proper footings don't have to be concrete, they could be gravel pads. A proper (pressure-treated) wood foundation will use gravel footings to provide drainage under the wood.
Cheers, Wayne
I really appreciate your help, Wayne! The blocks are stone and the shims are wood.
wwhitney
Berkeley, CA
The main problem with the stone stacks is that there's nothing holding the stack together, so in a good windstorm or earthquake, things could easily shift to the detriment of your structure. [Plus the stones should be partially buried in the soil, which is impossible to verify from the photos.]
And as to your original question, what you have isn't suitable for a water tank, but if you are interested in fixing your existing footings, the additional work for the water tank would likely just be two more footings and some framing. You'd want to get an engineer to design all that for you, rather than listen to some person on the Internet.
Cheers, Wayne
Cheers, Wayne[/QUO
Cheers, Wayne
Good point Wayne but Engineers arent free. Looking at your building Id consult with an experianced foundation and structural man, at a minimum possibly engineer . but im thinking out there in Yukon its probebly kind of in the sticks like homesteader cabins. In which case Id use whoever was good at this stuff. because It doesent seem your going to be able to figure it out with out help
Cahoffa
Yukon, Canada
Cheers, Wayne
Yes, I will! Thank you, Wayne!
